ANH DUY AUDIO 172 PASTEUR,QUẬN 1: AMPLI DENON PMA 2500
Dành cho các nhà sản xuất, lắp ráp và kinh doanh sản phẩm nghe nhìn.
Các điều hành viên: tranman, tai_trau, titoet, BachDuong, Moderators
Re: ANH DUY AUDIO 172 PASTEUR, QUẬN 1
Gửi bàigửi bởi AnhDuy » 04 Tháng 4 2013, 10:09
Loa MartinLogan Electromotion FX2 Surround
Hình ảnh
Frequency response: 55–25,000 Hz ±3 dB
Recommended amplifier power: 20 - 200 watts per channel
Sensitivity: 93 dB @ 2.83 volts / meter
Dispersion: 160-degrees x 30-degrees
Nominal impedance: 5 ohms (compatible with 4, 6 or 8 ohm rated amplifiers)
Crossover frequency: 2,300 Hz
Dimensions: 14.9" high, 14" wide, and 6.8" deep
Weight: 16 lbs.
Hình ảnh
GIÁ: 650 USD/ CẶP ( 13.650.000 VND )
ANH DUY AUDIO
172 Pastuer, Q1 TP HCM
STK: 65256999 - NGÂN HÀNG Á CHÂU HCM - Chủ TK: NGUYỄN PHÚC QUÝ
ĐT: 0906805953
Hình đại diện của thành viên
AnhDuy
Shop
Ngày tham gia: 19 Tháng 8 2008, 09:53
Gửi bàigửi bởi AnhDuy » 04 Tháng 4 2013, 10:35
Loa MartinLogan Motif 230V DK Cherry (Center)
Hình ảnh
equency Response
73–20,000 Hz ±3dB
Horizontal Dispersion
30°
High Frequency Transducer
1" (2.5cm) neodymium soft dome
Mid Frequency Transducer
Patented CLS™ XStat™ electrostatic transducer
» Panel Dimensions
5.4" × 15" (13.7 × 38.1cm)
» Radiating Area
81 in2 (522 cm2)
Low Frequency Transducer
Two 5.25" (13.4 cm) cast basket, neodymium magnet, aluminum cone with extended throw driver assembly, non-resonant asymmetrical chamber format; shielded
Sensitivity
89 dB/2.83 volts/meter
Impedance
Nominal: 6 Ohms
Minimum: 4 Ohms. Compatible with 4, 6, or 8 Ohm rated amplifiers.
Recommended Amplifier Power
20‒300 watts per channel
Crossover Frequency
450, 4000 Hz
Components
Air core coils
Inputs
Custom 5-way binding posts
Weight
22.5 lbs. (10.2 kg)
Dimensions (with non-skid feet)
7.6" × 29.75" × 9"
(19.3cm × 75.6cm × 22.9cm)
Dimensions (with stand)
10" × 29.75" × 9"
(25.4cm × 75.6cm × 22.9cm)
GIÁ: 1.890 USD/CÁI ( 39.690.000 VND )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 04 Tháng 4 2013, 11:18
MartinLogan Dynamo 700 230V W/SWT2(Sub)
Hình ảnh
Frequency Response
24–200 Hz ±3dB; Anechoic through LFE effects input
Wireless Receiver
Built-in receiver (SWT-1 transmitter sold seperately)
Low Pass Filter Frequency
35–120 Hz
10" (25.4cm) high excursion, poly cone with extended throw drive assembly; sealed non-resonant cabinet design
Amplifier
300 watts (600 watts peak)
Impedance
Line level RCA: 20,000 Ohms. Compatible with 4, 6, or 8 Ohm rated amplifiers.
Audio Controls
Low Pass Filter Switch: Bypass (LFE In), Variable (Left and Right In)
Inputs
Left and Right/LFE RCA line level
Power Draw
Standby: 1W
Idle: 15W
Max: 400W
Compatible Products
SWT-1 Subwoofer Wireless Transmitter, sold seperately
Resolution
16-bit
Sampling Rate
48kHz
Wireless Band
2.4GHz uncompressed digital self-sensing design constantly adjusts for best connection.
Error Checking
Bidirectional feedback constantly monitors integrity of data stream.
Antenna
Internal
Subs Per Transmitter
One
Maximum Wireless Range
30–40 feet (10–12.5 meters)
Weight
26.5 lbs. (12 kg)
Dimensions (down-firing orientation)
12.54" × 11.69" × 12.53"
(31.9cm × 29.7cm × 31.8cm)
Dimensions (front-firing orientation)
13.47" × 11.69" × 12.31"
(34.2cm × 29.7cm × 31.3cm)
Hình ảnh
GIÁ: 750 USD/CÁI ( 15.750.000 VND )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 04 Tháng 4 2013, 11:26
MartinLogan Dynamo 1000 230V W/SWT2(Sub)
Hình ảnh
Frequency Response
22–200 Hz ±3dB; Anechoic through LFE effects input
Wireless Receiver
35–120 Hz
12" (30.5cm) high excursion, poly cone with extended throw drive assembly; sealed non-resonant cabinet design
Amplifier
500 watts (1000 watts peak)
Impedance
Audio Controls
Inputs
Power Draw
Standby: 1W
Idle: 15W
Max: 650W
Compatible Products
Resolution
16-bit
Sampling Rate
48kHz
Wireless Band
Error Checking
Antenna
Internal
One
Weight
34 lbs. (15.4 kg)
14.54" × 13.69" × 14.59"
(36.9cm × 34.8cm × 37.1cm)
15.46" × 13.69" × 14.35"
(39.3cm × 34.8cm × 36.4cm)
GIÁ: 1.100 USD/CÁI ( 23.100.000 VND )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 04 Tháng 4 2013, 11:49
Loa MartinLogan Descent I 230V DK Cherry/BL(sub)
Hình ảnh
Frequency Response
18–120 Hz ±3dB; Anechoic through LFE effects input
30, 35, 45, 55, 65, 80Hz
High Pass Filter Frequency
Bypass, 40Hz, 70Hz
Three 10" (25.4cm) high excursion, aluminum cone with extended throw drive assembly, sealed non-resonant asymmetrical chamber format
Amplifier
Three 250W (at less than 0.24% THD)
Three 700W (peak)
2100W (peak, system total)
Impedance
Audio Controls
±10dB at 25Hz
±10dB at 50Hz
Inputs
Left/Right RCA Line Level, RCA and XLR LFE, Speaker Level
Power Draw
Max: 750 Watts
Idle: 30 Watts
Standby: 10 Watts
Weight
105 lbs. (47.7 kg)
Dimensions
21.4" × 20.5" × 19.9"
(54.4cm × 51.9cm × 50.5cm)
Hình ảnh
GIÁ: 3.400 USD /CÁI ( 71.400.000 VND )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 07 Tháng 4 2013, 15:58
Denon N5
Hình ảnh
DRA-N5 NETWORK RECEIVER NEW FEATURES
Compact body with high quality sound
AirPlay for direct link to iDevice and iTunes
"Play to" from Windows Media Player 12 (or higher)
Plays music from PC/NAS and online services
Spotify and last.fm online support
Internet radio and network audio streaming via Ethernet and Wi-Fi (antenna built in)
Supports MP3, WMA, AAC, FLAC 192/24, WAV 192/24, ALAC
Gapless playback
iPhone/iPod dock on top with digital connection (30pin connector)
Support iPod Charge in standby mode
Controllable with New Denon Remote App from iPhone/iPod Touch, iPad, and Android
3 line OELD (Organic Electroluminescence Display) display with high contrast and wide view
Digital input for upgrading the sound of your TV set or other sources with optical digital output
Supports Wi-Fi Multi Media (WMM)
STATE-OF-THE-ART DENON SOLUTIONS FOR MAXIMISING CONTENT QUALITY
65 W + 65 W, high power output (4 ohms, 1 kHz)
Integrates Denon hi-fi component sound engineering into compact size
“Simple & straight” circuit design and minimum signal path, to optimize performance in sound quality
Fully digital concept from input signal to output power stage
Optimising Filter, to align the DRA-N5 with SC-N5 speaker system characteristic
Binding post speaker terminals
Hình ảnh
GIÁ: 550 USD ( 11.550.000 VND )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Re: ANH DUY AUDIO 172 PASTEUR, QUẬN 1 thanh ly amply va DVD
Gửi bàigửi bởi AnhDuy » 08 Tháng 4 2013, 14:35
DENON N8
Hình ảnh
Digitally transmitted play function for iPhone/iPod (built-in iPod dock)
- CD, WMA/MP3 (CD-R/RW)
- FM radio
- AirPlay
- Internet radio
- PC/NAS music files streaming
- Online music service, Last.fm (*1)
- WAV 192kHz/24bit, FLAC 192kHz/24bit content support
- DLNA 1.5 certified
- Windows 7 compatible
- Digitally transmitted play function for iPhone/iPod (built-in iPod dock)
- USB memory/USB memory player (mass storage audio support)
- Digital input for TV
*1): Last.fm is not available in all countries.
High-quality sound in a compact body
- Full digital sound engineering
- 65 W + 65 W, high power output (4 ohms, 1 kHz)
- Newly developed quality 2-way 2 speaker system with gold screw terminals
- 2 way, 2 speaker system, 12 cm cone bass-mid, 2.5 cm balanced dome tweeter
- "Simple & straight" circuit design and minimum signal path, to optimise performance in sound quality
- Optimising Filter, to align the RCD-N8 with SC-N8 speaker system characteristic
GIÁ: 895 USD (18.795.000 VND)
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 10 Tháng 4 2013, 16:14
DENON F 109
Hình ảnh
Dàn máy mini D-F109 với 3 thớt ( tùy chọn). Đầu CD có ngõ cắm USB. Thớt Network ngõ USB chạy được WAV 192 kHz/24 bit, FLAC 192 kHz/24 bit. Ampli có tầng công suất mạch class D, mạnh mẽ. Ngõ vào digital gồm ngõ Coaxial và Optical có thể dùng kết nối với đầu HD xem phim. Ampli có ngõ ra SUB OUT dùng kết nối loa sub ngoài để tăng cường bass.
Thích hợp phòng nhỏ, cá nhân, phòng ngủ.
Thiết kế sang trọng, ngỏ gọn
Main Specifications:
DRA-F109
Receiver section
- Rated output / 65 W + 65 W (4 ohms, 1 kHz, T.H.D. 0.7%), Speaker 4 – 16 ohms, Suited for headphones/stereo headphones
- Input sensitivity / 200 mV/47 kohms
- Tone control / S.D.B.: 100 Hz + 8 dB, Treble 10 kHz ±10 dB, Bass 100 Hz ±10 dB
FM section
- Tuning frequency range / 87.5 - 108 MHz
General
- Power supply / AC 230 V, 50/60 Hz
- Power consumption / 48 W
- Power consumption in standby mode / 0.3 W
- Dimentions (W x H x D) / 250 x 82 x 250 mm (w/o terminals), 250 x 82 x 283 mm
- Weight / 2.6 kg
Main Specifications: DNP-F109
Analog audio section
- Playable frequency range / 2 Hz - 96 kHz
- Playable frequency response / 2 Hz - 50 kHz (Sampling frequency: 192 kHz), 2 Hz - 20 kHz (Sampling frequency: 44.1 kHz)
- S/N / 110 dB (Audible Range)
- Dynamic Range / 98 dB (Audible Range)
- Harmonic Distortion / 0.0035 % (1 kHz, Audible Range)
- Output Level / 2.0 Vrms
Wireless LAN section
- Network type (wireless LAN standards) / Conforming to IEEE 802.11 b, Conforming to IEEE 802.11 g
General
- Power Supply / AV 230 V, 50/60 Hz
- Power consumption / 16 W
- Power consumption in standby mode / 0.2 W
- Power consumption in “Network Control” - “on” mode / 6 W
- Dimensions (W x H x D) / 250 x 82 x 250 mm (w/o terminals), 250 x 82 x 257 mm
- Weight / 2.0 kg
Main Specifications: DCD-F109
General
- Power consumption / 25 W
- Power consumption in stadby mode / 0.3W
- Dimensions (W x H x D) / 250 x 82 x 250 mm (w/o terminals), 250 x 82 x 264 mm
- Weight / 2.8 kg
Main Specifications: SC-F109
- Type / 2-way, 2-speakers Relax box
- Frequency / 40 Hz - 40 kHz
- Input impedance / 6 ohms
- Max. input / 60 W (IEC), 120 W (PEAK)
- Speakers / 12 cm cone bass-mid x1, 2.5 cm soft dome high range x1
- Dimensions (W x H x D) / 165 x 245 x 234 mm
- Weight / 3.8 kg/unit
GIÁ: 22.500.000 VND )
Sửa lần cuối bởi AnhDuy vào ngày 12 Tháng 7 2016, 10:22 với 1 lần sửa trong tổng số.
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 12 Tháng 4 2013, 11:02
LOA KLIPSCH RF 7 II
Hình ảnh
Klipsch Reference II là series được cải tiến từ Reference trước đây. Model RF 7II là sản phẩm lớn nhất của Series này. Loa có độ nhạy 101dB, củ loa thuộc thế hệ mới nhất do chính hãng Klipsch sáng chế. Hệ thống phân tần ( Crossover) được cải tiến lại hòan tòan.
Các đặc điểm nổi bật
Loa treble titanium và thiết kế theo dạng loa còi truyền thống của Klipsch ( Tracktrix Horn)
Màng loa bass được làm từ hợp chất Alunium và các vật liệu dùng trong ngành hàng không, giúp loa có màng cứng nhẹ dễ dàng họat động nhanh, đáp ứng tốt các tần số
Vỏ loa làm được bọc bằng gỗ thật
Chân loa cứng chắc
Thông số
FREQUENCY RESPONSE 30Hz-24KHz ± 3dB
POWER HANDLING 250W RMS / 1000W Peak
SENSITIVITY 101dB @ 2.83V / 1m
NOMINAL IMPEDANCE 8 ohms compatible
CROSSOVER FREQUENCY 1200Hz
HIGH FREQUENCY DRIVERS 1.75" (4.45cm) Titanium diaphragm compression driver
HIGH FREQUENCY HORN 8" square 90° x 60° Tractrix® Horn
LOW FREQUENCY DRIVERS Two 10" (25.4cm) Cerametallic™ cone woofers
ENCLOSURE TYPE Bass-reflex via dual rear-firing ports
INPUTS Dual binding posts / bi-wire / bi-amp
HEIGHT 48.5" (123.3cm) with feet
WIDTH 11.6" (29.5cm)
DEPTH 16.3" (41.5cm) with grille
WEIGHT 87.1lbs (39.5kg)
FINISHES Black Ash , Medium Cherry furniture grade wood veneer
GIÁ: 65.540.000 VND )
Sửa lần cuối bởi AnhDuy vào ngày 12 Tháng 7 2016, 10:25 với 1 lần sửa trong tổng số.
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 12 Tháng 4 2013, 11:10
LOA KLIPSCH RF 82 II
Hình ảnh
RF 82II là loa đứng thuộc dòng Reference II của Klipsch Loa có 3 đường tiếng, dùng treble thuộc lọai Tractrix Horn. Loa được nâng cấp từ phiên bản Rf 82, cải tiến lại bộ Crossover ( phân tần) và dùng củ loa lọai mới. Âm thanh mềm mại và nhạc tính hơn.
Thông số kỹ thuật
FREQUENCY RESPONSE 33Hz-24KHz ± 3dB
POWER HANDLING 150W RMS / 600W Peak
SENSITIVITY 98dB @ 2.83V / 1m
HIGH FREQ CROSSOVER 1400Hz
HIGH FREQUENCY DRIVERS 1" (2.54cm) Titanium diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
LOW FREQUENCY DRIVERS Dual 8" (20.3cm) Cerametallic™ cone woofers
HEIGHT 43.9" (111.4cm) with feet
WIDTH 9.3" (23.5cm)
DEPTH 16.3" (41.4cm) with grille
WEIGHT 61.5lbs (32.2kg)
FINISHES Black Ash & Cherry woodgrain vinyl
BUILT FROM 2010
Hình ảnh
GIÁ: 1.350 USD ( 28.350.000 VND )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 12 Tháng 4 2013, 11:24
LOA KLIPSCH RB 81 II
Hình ảnh
Loa RB81II của Klipsch thuộc dòng Reference II. Loa được nâng cấp từ dòng Reference cũ, cải thiện chất âm trong trẻo và chi tiết hơn. Loa có độ nhạy cao 97 dB, phù hợp cho phòng nhỏ nhưng cho tiếng bass mạnh mẽ. Dễ phối ghép với Ampli, đặc biệt Ampli bóng đèn, cho tiếng Mid thật trong và giàu nhạc tính.
:: Thông số kỹ thuật
FREQUENCY RESPONSE 44Hz-24KHz ± 3dB
SENSITIVITY 97dB @ 2.83V / 1m
LOW FREQUENCY DRIVERS 8" (20.3cm) Cerametallic™ cone woofer
ENCLOSURE TYPE Bass-reflex via front-firing port
HEIGHT 19" (48.4cm)
WIDTH 9.3" (23.5cm)
DEPTH 12.3" (31.2cm) with grille
MOUNTING Dual bottom mount 1/4"-20 threaded inserts
WEIGHT 27.5lbs (12.5kg)
GIÁ: 13.340.000 VND )
Sửa lần cuối bởi AnhDuy vào ngày 12 Tháng 7 2016, 10:27 với 1 lần sửa trong tổng số.
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 12 Tháng 4 2013, 11:27
LOA KLIPSCH RB 61 II
Hình ảnh
Loa RB 61II có độ nhạy 95 dB, công suất đạt được 100W nhưng có công suất đỉnh đến 400W. Loa dễ phối ghép với Ampli, dù có công suất nhỏ.
:: Thông số kỹ thuật :: Hình ảnh ::
FREQUENCY RESPONSE 45Hz-24KHz ± 3dB
POWER HANDLING 100W RMS / 400W Peak
SENSITIVITY 95dB @ 2.83V / 1m
HIGH FREQ CROSSOVER 1500Hz
LOW FREQUENCY DRIVERS 6.5" (16.5cm) Cerametallic™ cone woofer
HEIGHT 15.4" (39.1cm)
WIDTH 8.5" (21.6cm)
MOUNTING None
WEIGHT 35.2lbs (16kg) per pair
BUILT FROM 2010
GIÁ: 10.170.000 VND )
Sửa lần cuối bởi AnhDuy vào ngày 12 Tháng 7 2016, 10:28 với 1 lần sửa trong tổng số.
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 12 Tháng 4 2013, 11:33
LOA CENTER KLIPSCH RC 64 II
Hình ảnh
Một loa centre xứng đáng để phối ghép cho những bộ dàn xem phim chất lượng cao nhất. Hệ thống loa với 4 loa mid và 1 loa treble còi trong một kích thước loa dài gần 1 mét, đảm bảo cho lời thoại diễn viên tái hiện rõ ràng, nổi bật nhưng trong rạp chiếu phím chuyên nghiệp
Thông số
DEPTH: 13" (33cm) with grille
HEIGHT: 8" (20.3cm)
WIDTH: 35.8" (91cm)
ENCLOSURE TYPE: Sealed
FINISHES: Black Ash , Medium Cherry furniture grade wood veneer
FREQUENCY RESPONSE: 59Hz-24KHz ± 3dB
HIGH FREQUENCY CROSSOVER: 1100Hz, 1400Hz
HIGH FREQUENCY DRIVER: 1.75" (3.2cm) Titanium diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
INPUTS: Dual binding posts / bi-wire / bi-amp
LOW FREQUENCY DRIVER: Quad 6.5" (16.5cm) Cerametallic cone woofers
MOUNTING: Uptilt and Downtilt feet
NOMINAL IMPEDANCE: 8 ohms compatible
POWER HANDLING: 200W RMS / 800W Peak
SENSITIVITY: 99dB @ 2.83V / 1m
WEIGHT: 51.8lbs (23.5kg)
GIÁ: 26.400.000 VND )
Sửa lần cuối bởi AnhDuy vào ngày 12 Tháng 7 2016, 14:30 với 1 lần sửa trong tổng số.
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 12 Tháng 4 2013, 11:36
LOA CENTER KLIPSCH RC 62 II
Hình ảnh
FREQUENCY RESPONSE 57Hz-24KHz ± 3dB
LOW FREQUENCY DRIVERS Dual 6.5" (16.5cm) Cerametallic™ cone woofers
ENCLOSURE TYPE Bass-reflex via dual front-firing ports
INPUTS Single binding posts
HEIGHT 8" (20.3cm)
WIDTH 23.5" (59.7cm)
DEPTH 12.8" (32.4cm) with grille
MOUNTING Uptilt and Downtilt feet
WEIGHT 30.4lbs (13.8kg)
BUILT FROM 2010
GIÁ: 690 USD ( 14.490.000 VND )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 12 Tháng 4 2013, 11:43
LOA CENTER KLIPSCH RC 52 II
Hình ảnh
Loa centre RC 52II có độ nhạy cao đến 96 dB cho âm thanh thoại cực rõ nét Loa bao gồm 1 loa treble tractrix và 2 loa bass với màng loa bằng hợp chất gốm và kim lọai.
BUILT FROM: 2010
DEPTH: 26.6 cm with grille
ENCLOSURE TYPE: Bass-reflex via dual front-firing ports
FINISH: Black Ash woodgrain vinyl
FREQUENCY RESPONSE: 67Hz-24KHz ± 3dB
HEIGHT: 6.5" (16.6cm)
HIGH FREQUENCY CROSSOVER: 1600Hz
HIGH FREQUENCY DRIVER: 1" (2.54cm) Titanium diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
INPUTS: Single binding posts
LOW FREQUENCY DRIVER: 2 x 13.3cm Cerametallicâ„¢ cone woofers
NOMINAL IMPEDANCE: 8 Ohms compatible
POWER HANDLING: 125W RMS / 500W Peak
SENSITIVITY: 96dB @ 2.83V / 1m
WEIGHT: 22.1lbs (10kg)
WIDTH: 20.5" (52.1cm)
GIÁ: 320 USD ( 6.720.000 VND )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 12 Tháng 4 2013, 11:46
LOA CENTER KLIPSCH RC 42 II
Hình ảnh
BUILT FROM: 2010
DEPTH: 8.9" (22.7cm) with grille
FREQUENCY RESPONSE: 88Hz-24KHz ± 3dB
HEIGHT: 5.4" (13.7cm)
HIGH FREQUENCY CROSSOVER: 1700Hz
LOW FREQUENCY DRIVER: Dual 4" (10.2cm) Cerametallic cone woofers
POWER HANDLING: 75W RMS / 300W Peak
SENSITIVITY: 95dB @ 2.83V / 1m
WEIGHT: 12.6lbs (5.7kg)
WIDTH: 16" (40.7cm)
GIÁ: 220 USD ( 4.620.000 VND )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 12 Tháng 4 2013, 11:50
LOA CENTER KLIPSCH C 20
Hình ảnh
BUILT FROM: 2010
CROSSOVER FREQUENCY: 2150Hz
DEPTH: 6.47" (16.4cm)
FINISH: Black Ash vinyl
FREQUENCY RESPONSE: 82Hz-23KHz ± 3dB
HEIGHT: 7.5" (19.2cm)
HIGH FREQUENCY DRIVER: 1" (2.54cm) Aluminum diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
LOW FREQUENCY DRIVER: Dual 5.25" (13.3cm), magnetically shielded IMG woofers
MOUNTING: Downtilt foot
POWER HANDLING: 100W RMS / 400W Peak
SENSITIVITY: 95.5dB @ 2.83V / 1m
WEIGHT: 10lbs (4.5kg)
WIDTH: 19.8" (50.3cm)
GIÁl: 210 USD ( 4.410.000 VND )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 12 Tháng 4 2013, 11:52
LOA CENTER KLIPSCH C 10
Hình ảnh
BUILT FROM: 2010
CROSSOVER FREQUENCY: 3000Hz
DEPTH: 5.25" (13.3cm)
FREQUENCY RESPONSE: 100Hz-23KHz ± 3dB
HEIGHT: 6" (15.2cm)
HIGH FREQUENCY CROSSOVER: .75" (1.9cm) Aluminum diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
LOW FREQUENCY DRIVER: Dual 4" (10.2cm), magnetically shielded IMG woofers
POWER HANDLING: 50W RMS / 200W Peak
SENSITIVITY: 93.5dB @ 2.83V / 1m
WEIGHT: 8lbs (3.6kg)
WIDTH: 16" (40.6cm)
GIÁ: 170 USD ( 3.570.000 VND )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 12 Tháng 4 2013, 12:44
LOA SURROUND KLIPSCH RS 62 II
Hình ảnh
FREQUENCY RESPONSE 50Hz-23kHz +/-3dB
SENSITIVITY 97dB @ 2.83V / 1m (equivalent sound energy)
HIGH FREQ CROSSOVER 2000Hz
HIGH FREQUENCY DRIVERS Dual 1" (2.54cm) Titanium diaphragm compression drivers mated to 90x60 square Tractrix® Horns
ENCLOSURE TYPE Bass-reflex via quad side-firing ports
HEIGHT 15" (38.1cm)
WIDTH 14.75" (37.5cm)
DEPTH 9.75" (24.8cm)
MOUNTING Keyhole bracket and Dual 1/4"-20 threaded inserts
WEIGHT 28lbs (12.7kg)
FINISHES Matte Black vinyl
Hình ảnh
GIÁ: 790 USD ( 16.590.000 VND )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 12 Tháng 4 2013, 12:47
LOA SURROUND KLIPSCH RS 52 II
Hình ảnh
FREQUENCY RESPONSE 58Hz-24KHz ± 3dB
HIGH FREQUENCY DRIVERS Dual 1" (2.54cm) Titanium diaphragm compression drivers mated to 90° x 60° square Tractrix® Horns
LOW FREQUENCY DRIVERS Dual 5.25" (13.3cm) Cerametallic™ cone woofers
ENCLOSURE TYPE Bass-reflex via dual side-firing ports
HEIGHT 13" (33.1cm)
WIDTH 14.3" (36.3cm)
DEPTH 8" (20.2cm)
MOUNTING Keyhole bracket and quad 1/4"-20 threaded inserts
WEIGHT 14.7lbs (6.7kg)
BUILT FROM 2010
GIÁ: 590 USD ( 12.390.000 VND )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 12 Tháng 4 2013, 13:10
LOA SURROUND KLIPSCH RS 42 II
Hình ảnh
FREQUENCY RESPONSE 52Hz-23kHz +/-3dB
POWER HANDLING 75W RMS / 300W Peak
SENSITIVITY 93dB @ 2.83V / 1m (equivalent sound energy)
HIGH FREQ CROSSOVER 1700Hz
LOW FREQUENCY DRIVERS Dual 4" (10.2cm) Cerametallic™ cone woofers
HEIGHT 10" (25.4cm)
WIDTH 10.75" (27.3cm)
DEPTH 7.75" (19.7cm)
WEIGHT 10lbs (4.5kg)
BUILT FROM 2006
BUILT UNTIL 2010
GIÁ: 490 USD ( 10.290.000 VND )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 12 Tháng 4 2013, 13:12
LOA SURROUND KLIPSCH S 20
Hình ảnh
SPECIFICATIONS
BUILT FROM: 2010
DEPTH: 5.5" (13.9cm)
ENCLOSURE TYPE: Sealed (WDST)
FREQUENCY RESPONSE: 83Hz-23KHz ± 3dB
HEIGHT: 6.85" (17.4cm)
HIGH FREQUENCY DRIVER: Dual 1" (2.54cm) Aluminum diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
LOW FREQUENCY DRIVER: 5.25" (13.3cm), IMG woofer
MOUNTING: Keyhole Bracket
SENSITIVITY: 91dB @ 2.83V / 1m
WEIGHT: 7lbs (3.2kg)
WIDTH: 14.3" (36.3cm)
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 12 Tháng 4 2013, 13:14
LOA SURROUND KLIPSCH S 10
Hình ảnh
BUILT FROM: 2010
CROSSOVER FREQUENCY: 2800Hz
DEPTH: 4.6" (11.7cm)
FREQUENCY RESPONSE: 95Hz-23KHz ± 3dB
HEIGHT: 5.6" (14.2cm)
HIGH FREQUENCY DRIVER: Dual .75" (1.9cm) Aluminum diaphragm compression driver mated to 90° x 60° square Tractrix® Horn
LOW FREQUENCY DRIVER: 4" (10.2cm), IMG woofer
SENSITIVITY: 89dB @ 2.83V / 1m
WEIGHT: 5lbs (2.3kg)
WIDTH: 11.8" (30cm)
GIÁ: 250 USD ( 5.250.000 VND )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 15 Tháng 4 2013, 16:22
LOA JBL CONTROL 25 LOA TREO TƯỜNG DÙNG OUTDOOR/INDOOR CHO CAFE, SPA, NHẠC NỀN....
Hình ảnh
Frequency Range : 80 Hz to 16 kHz
(-10 dB)
Power Capacity : 150 W Continuous
Program Power
75 W Continuous
Pink Noise
Sensitivity : 88 dB SPL,
1 W, 1m
Directivity Factor (Q) : 5.3 dB
Directivity Index (DI) : 7.2 dB
Nominal Impedance : 8 ohms
Crossover Frequency : 3.0kHz
Frequency LF Driver : 135mm (5.25 in) Polypropylene cone w/ WeatherEdge
HF Driver : 19mm (.75 in) Titanium coated polycarbonate
Enclosure Material : HIPS (High Impact Polystyrene)
Overload Protection : Full-Range power limiting to protect network and transducers
Terminations : Spring terminals, accepts banana plug
Environmental : Conforms to Mil Spec 810 for humidity, salt spray,temperature& UV. IEC 529 IP-X4 splashproof rating
Dimensions (H x W x D) : 236 x 188 x 149 mm (9.3 x 7.4 x 5.8 in)
Net Weight (ea) : 2.3 kg (5 lb)
Shipping Weight (ea) : 5 kg (11 lb)
Included Accessories : Invisiball Assembly
GIÁ: 3.620.000 VND/CÁI )
Sửa lần cuối bởi AnhDuy vào ngày 12 Tháng 7 2016, 14:33 với 1 lần sửa trong tổng số.
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Gửi bàigửi bởi AnhDuy » 15 Tháng 4 2013, 16:26
LOA JBL CONTROL 28 LOA TREO TƯỜNG DÙNG OUTDOOR/INDOOR CHO CAFE, NHẠC NỀN, KARAOKE ....
Hình ảnh
Specifications:
Frequency Range (-10 dB)1
: 60 Hz to 16 kHz
Continuous Program:
Power Capacity2
: 175 Watts
Sensitivity3
: 92 dB SPL, 1W, 1m
Directivity Factor (Q): 7.5
Directivity Index (DI): 8.8
Nominal Impedance: 8 ohms
Crossover Frequency: 2.8 kHz
LF Driver: 200 mm (8 in) Polypropylene cone w/WeatherEdge
HF Driver: 25 mm (1 in) Titanium coated polycarbonate
Enclosure Material: HIPS (High Impact Polystyrene)
Overload Protection: Full-Range power limiting to protect network and transducers
Termination: Spring terminals, accepts banana plug
Environmental: Conforms to Mil Spec 810 for humidity, salt spray,
temperature & UV. IEC 529 IP-34 splashproof rating.
Dimensions (H x W x D): 380 x 280 x 220 mm (15.0 x 11.0 x 8.6 in)
Net Weight (ea): 5.5 kg (12 lb)
Shipping Weight (pr): 11 kg (25 lb)
Included Accessories: Invisiball Assembly
6 mm x 180 mm hex key
Optional Accessories:
MTC-28V: For vertical columnar orientation of up to 3 loudspeakers
MTC-28H: For horizontal splaying of two speakers. Three brackets array
up to six loudspeakers in a 360° array.
MTC-28/25CM: Ceiling-mount adapter.
MTC-23SSG: Stainless Steel Grille for harsh environments. Available in
silver, black (-BK) or white (-WH)
MTC-23WMG: WeatherMax™ Stainless Steel Grille protects against driving
precipitation. Available in black or white (-WH)
MTC-PC2: Input panel cover protects input terminals in outdoor
GIÁ: 6.330.000 VND /CÁI )
ANH DUY AUDIO
ĐT: 0906805953
AnhDuy
Shop
Trang trướcTrang kế tiếp
Quay về VNAV Shop - Showrooms
Ai đang trực tuyến?
Đang xem chuyên mục này: ADAUDIO, Aeolus Kratos, ailangthang, ancoi2009hd, anhdiep, AnhDuy, anhthuong, anphucluxman, Aping, audax, audio509, audio_thanhconghanoi, Audiothienha, Babybaby, bala, Baoanh_Hue, baoanth, batnc, batuocbongdem, beman82, berot89, Bigwall, Capstan, Chương Nhật Tảo, cottu, cuinhl, cunhovn, DaNangTubes, Dang Quang Hai, davidak, Deja_Vu, dgnguyen, dia than JOLIE, DienmayHaiThinh, doanhcuongkt, domanhcuong, DON-252, dreamerr, dubingo1720, DUCPHE, dungdiep, dunghpc, dungtrieu, duyen38, Đặng Xuân Quang, FaceBook [Linkcheck], Floynd, giahuyaudio, giaoclub, giarau999, hacuongnp, haitgtm, hieudtgt, hiiii2222, hmtuvietinbank, Hoang Cuong, hoang.duyvien, hoanglongsw, HuanNT, HungBMT, hungbo, Hungct, hunggo, Hungtc, huntvn, Hùng kều, Hải Thiên, jti, kienminh06, Kiunguyen, lam401, leducquynh, lehoangdong, linhho12, linux408, long2005, love_tube, Lovemusic_Hp, luxman58a, manhvynd, minh, minh66, Minhnguyen76, minhrau, minhthuan, mrdungjk, mrhatuvu, MrSon, mxvmxv, MY AUDIO, N3T, Nam Dinh Tubes, namvuong, Nghia-NTN, ngoc8989, ngocchau, ngocquyhp, nguoicungkho, nguyen van nam, nguyenbatue, Nguyenlb1977, nguyenquan11, Nguyễn Thắng, nhathoang, nhkvn, ntuonghn, octieuvn, PGC2003, phamdinhnghia, phancuong78, phongthanhafcvn, Phuchagiang, phuonggctg, phuongmitec, PHUONGMULTI, Planets, pqhung2005, PTT79, QTman, quangcmbhn, quangtrang77, QUOCTHONG_7951, saigon198, sakura, smallvill, SonAudio_HN, sonlg, superwagon, tackehoa, taimono, thaichhao2008, thainhnh, thangkv, thangsamnec, Thanhdo, thanhtroc, TheHung, thelord, thienphucgo, Thinhtd, Tomrui, tqthien, Trinh Cuong, trinhgate, trinhngoc293, trinhnq, truc123, trunggugu, truongxuanthu, tuan A&C, Tuan Brother, Tuan TLSQ, TUANLOM, tuansg, tumin20023101, tungdan, Tuyen2068, ukno1, Usain Bolt, vanhd_cpc, vdatu106, viethai1819, vietpham2610, Vina-NVC, vinh_k5, Vintage audio, vndiyshop, voicoidang, VQT, Wollensak, xmensport, yyhanh, zoomx6213 khách
